  #1
Old February 1st, 2009, 04:54 PM
Fester's Avatar
Fester Fester is offline
Default Evinrude LightWin Smoking
I have a 1969 Evinrude Sportwin 4 HP motor and I just cranked it up and found that it smokes a bit more than usual and it is leaving oily deposits in the water barrel. I was running a 40:1 mixture but was advised top switch to 50:1. Well, that's what I did and I am not sure that it may be the cause. This was the 1st time I cranked her up in over 8 months. Is the smoking and deposits due to just it sitting for a while or could there be serious underlying problems? Thanks in advance!
  #2
Old February 1st, 2009, 05:25 PM
Vic.S's Avatar
Vic.S Vic.S is online now
Default Re: Evinrude LightWin Smoking
All sounds perfectly normal to me. Give it a good hard run and I bet the smoke will all but disappear. Time to worry is when it does not smoke at all. because you've probably forgot to mix the oil into the fuel.
That ones got high and low speed adjustments on the carb. when it has settled own it might be worth checking those as described in the "Engine FAQs"
50: 1 is the correct mix.
__________________
If it aint broke dont fix it!
If all else fails read the manual
  #3
Old February 1st, 2009, 05:35 PM
Fester's Avatar
Excellent News!!! Thanks Much!!!!
  #4
Old February 1st, 2009, 05:41 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
sounds normal for a barrel. but if it has never been done, and i doubt it has, a decarb would liven it up. gets the old built up crud out the internals.
Decarb, take a can of seafoam put 3/4 of it in the gas tank, with only 1 gallon of premixed gas. put the rest in a spray bottle. start the engine, and let it come up to temperature. then remove plugs, and them some real good shot of seafoam into the cylinders, replace plugs, let sit 15 minutes. restart, and spray the rest of the seafoam into the carbs, so the the motor almost stalls, wait and repeat until the seafoam is gone.then take for a wide open spin. then put in new plugs, ad premixed gas to the tank, and take it for a wide open throttle spin. it is going to smoke like a house on fire, during this process.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Evinrude Lightwin jwsimmons Johnson & Evinrude Outboards 1 February 14th, 2007 09:26 PM
Evinrude Lightwin Vince1 Johnson & Evinrude Outboards 5 July 18th, 2005 10:46 AM
lightwin evinrude twinlakes Non-Repair Outboard Discussions 1 March 4th, 2005 12:38 PM
4 evinrude lightwin Ol' Den Johnson & Evinrude Outboards 1 May 21st, 2004 11:09 PM
Evinrude Lightwin Robdogg Johnson & Evinrude Outboards 3 November 20th, 2002 03:22 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
