Re: Polyester Resin and Temp ?
You say these exact charts exist, but you can't produce one, interesting.
Actually like I said, there are charts, but they?re not exact, even for a specific resin, there are just too many variables that you have no control over.
We do QC testing with the same brand and type of catalyst the customer uses in their plant so it will simulate production a little better. To get even closer than normal we?ll have the customer ship catalyst from the batch they?re using and QC their product with it, this get?s it closer. As both products age their reactivity changes and gel times tend to be lengthened, so even if you made a chart using the exact batch of resin and the exact batch of catalyst, it may not be accurate in a month or so and sometimes even less depending on the product. If you change the brand of catalyst, even if it?s supposed to be an exact duplicate, you?ll get different results.
The other variable is the QC equipment and the person doing the testing, each piece of equipment will give a slightly different result and the operator can influence the test also. So even if you test the exact same products on the same day, by using different equipment and a different operator you?ll get different results.
The surfboard segment of the industry is one of the smallest there is and while there are a few resins formulated for it, little money is spent on it unless the same resin can be used in another much larger market.
Just because you didn?t see the negative effects of your less than desirable methods during your limited exposure to the FRP industry, doesn?t mean how you did it was correct. Or maybe you did see them, but didn?t have enough experience to recognize them for what they were.
