caddicruiser
- Nov 11, 2008
- 4
gentlemen I recently purchased a boat with a bad gas tank and a low hours 115 yam the console was detached I replaced the tank with a plastic moeller brand 25gal and reattached the console the motor fired right up upon first lake run it was ran strong for aprox 45mins then seemed to pull back as if starved for fuel or at 3/4 throttle upon inspection there was trash in the filter rubber particulates I then replaced the old fuel line and re-routed to eliminate possible pinch in line also added a in line filter (plastic cone shaped with a cartridge )it was in the marine fuel section not an automotive type in sequence with the existing that had a bad gasket at the filter ,this seemed to compound the problem it acted like it was getting air in the lines we could see bubbles in the inline filterthought maybe the tank inlet was floating or not enough fuel in the tank 3rd time out I re-routed the vent it was full of fuel in a low spot ,removed the inline filter installed new factory filter filled the tank with a short mix aprox 60:1 instead of 50:1 miscalculation on my part she ran good and strong out of the hole the backed off to 3/4 throttle 4th time strong again out of the hole then backed off and then died was able to restart 3 times limped back today I checked the compression 90psi each cylinder checked the fuel pump no tears seemed a bit corroded at the motor to pump area,and maybe a little loose there are no thermostats in place on either head need some help thanks G
