racoonbeast
- Sep 3, 2008
- 9
I have a 1971 Mercury 75 7.5 hp outboard. Can anyone tell me how to take the tiller assembly apart. Below the rubber throttle handle, as you work down the tiller handle is a ring. On the top is a round headed pin (parts list calls it a drive screw??) that also acts as the indicator on that ring as to when to throttle is turned to the start position. 360 degrees from that, around the ring, is a small hex set screw with a 3/32 hex wrench needed. I can get the hex screw out, but nothing happens in terms of taking it apart. It looks like the drive screw would have to come out before I could disassemble the entire tiller handle. I have taken the rubber handle off. No help there. Nothing to unscrew or remove. How would I get this "drive screw" out, or, is there another way to disassemble this unit. I need to strip it down completely. Got a back-up one that I want to exchange some parts with. Can anyone help? SN of outboard is 3018871. Thanks.
