Re: outdrive lifts in reverse
UU, not all outboards have one that work, especially those of us with large outboards with manual trim because the trim pin hooks don't hold up well to trailering.<br /><br />CPTMIKER's is a 1967 i/o which means it's been around a while so I assumed he had the same issue as mine does, which is that whatever is supposed to "grab" no longer grabs. In my case, the hook mechanism for the trim pin was done in when I bought it. I've seen plenty of other outboards with the same "problem" which makes no difference I can see unless you try to reverse too hard or tow with the leg down (bungee cord time!), although I'll admit I don't know if its the same for an I/O so maybe I'll modify my advice to suggest he gets his leg inspected to see if the problem is more serious for him. Thanks for pointing that out.
