Re: 150 EFI charging problems
CHARGING & STARTING SYSTEM
Battery Charging System Troubleshooting
General Troubleshooting
A fault in the battery charging system will usually cause the battery to become UNDERCHARGED.
A defective voltage regulator or a stator winding shorted to ground may also
allow the system to OVERCHARGE the battery.
If a problem exists in the charging system, visually check the following:
1. Check for correct battery polarity [RED cable to (+) POSITIVE battery terminal].
*NOTE: 40 AMP CHARGING SYSTEM voltage regulator/rectifier is protected internally
against incorrectly installed battery cables.
2. Check for loose or corroded battery terminals.
3. Check condition of the battery.
4. Visually inspect all wiring between stator and battery for cuts, chafing and disconnected,
loose or corroded connections.
5. Excessive electrical load (from too many accessories) will cause battery to run down,
even if the system is operating correctly.
If the system is still OVERCHARGING the battery, disconnect the YELLOW wire connector
from the regulator(s). Check for continuity between either YELLOW wire and ground
which would indicate a shorted stator winding. A short to ground in the stator bypasses
the regulation circuit of the voltage regulator resulting in overcharging of the battery. If the
YELLOW wires are not shorted to ground, the voltage regulator is most likely defective
and should be replaced.
If the battery is undercharged, proceed with regulator, stator, and rectifier tests, following.
40 Ampere Alternator System
40 AMP STATOR TEST (ALTERNATOR COILS ONLY)
*NOTE: Stator can be tested without removing from engine.
1. Disconnect YELLOW stator leads from voltage regulator connectors on starboard
side of engine.
2. Use an ohmmeter and perform the following test:
Test Leads To- Resistance
(Ohms)
Scale
Reading
Connect test leads between 2
YELLOW stator leads at each voltage
regulator connector.
0.18-.45* R x 1
RED test lead to 1 YELLOW stator
lead (voltage regulator connector),
and BLACK test lead to engine
ground if stator is mounted or to
steel frame of stator (if off engine)
No
Continuity
R x 1000
*NOTE: Resistance of these windings is less than one ohm. Copper wire is an excellent
conductor but will have noticeable differences from cold to hot. Reasonable variation from
specified reading is acceptable.
3. If meter readings are other than specified, replace stator assembly.
I hope this help you Post back what you find
