pizzafellow
- Mar 30, 2008
- 47
I followed Chiefalen post on servicing the tilt mechanism, I even took the motor apart and cleaned it, and put a new spring(which was missing) in the hammer-blow coupling, cleaned the clutch pack and oiled it( some of discs show a little wear on the kind of padding they have). with the motor out the worm gear turns easy with a screw driver but as soon as I put the motor back in ,when I hit the switch all I hear is the click both on the up and down solenoids.(even with the clutch pack out). Could the problem be the torque on the motor which I have no way of measuring.
Any tips will be greatly appreciated from this newbie to boating !!
