  #1
Old January 28th, 2009, 09:16 PM
deputydawg deputydawg is offline
Default Opinions on Mercury 150? Low compression.
I am looking at buying a 1990 Sea Ray 180 Bowrider. It has a Mercury 150, the picture looks like it says Black Max on the side. I have not seen the boat in person yet, only pictures. The dealer says one cylinder was "scorched" resulting in excessive cylinder leakage and low compression. Not sure what scorched means.
My question is what is everyones opinion on this outboard? Are there any common problems associated with this engine? Any ideas on what might cause one cylinder to have low compression? And finaly are there any online manuals I can check out before I decide to go look at the boat?
I am looking for a project boat. I am a mechanic, and have a friend who knows marine mechanics so the repairs are not a problem. Also curious if anyone else has run into this kind of problem and if an overhaul would fix the problem with the low compression.
Thanks.
  #2
Old January 28th, 2009, 09:52 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
Default Re: Opinions on Mercury 150? Low compression.
If it not locked up or thrown rod or piston thru block it can be fixed. The 1990 came two ways the 2.0 liter 150 and the 2.4 Xr4. Both are good engines and overhaul should fix engine. You will spend around $1200-1600 to get it right.
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
  #3
Old January 28th, 2009, 10:45 PM
Thanks for the reply. I am waiting now for an E-mail from the dealership mechanic as to specifics on what is wrong with it.
Is that 1200 to 1600 include labor for a marine mechanic to do the work, or is it only parts and machine work?
  #4
Old January 28th, 2009, 10:50 PM
Eshaw150 Eshaw150 is offline
that should be about the whole shabang
  #5
Old January 29th, 2009, 12:42 AM
Faztbullet's Avatar
This is for parts only,if in my shop labor would be around 650.00 12hr @ 55 per hour
6 pistons @ $100.00ea = 600.00
1 gasket set@ $100.00
1 misc bearings @ 250.00
1 impeller @ 25.00
3 carb kits @ $ 20.00=$60.00
1 misc sealers/cleaners= $35.00
Boring 6 @40.00ea =$240.00
misc shipping $30.00
grand total= $ 1330.00
__________________
  #6
Old January 29th, 2009, 02:36 AM
Thanks for the information.
Will have to see what the boat and engine look like, and see if they come down a little more on the price.
The dealer that has it has a very good reputation, is one of the biggest dealers in the area, and has been around a long time. I am comfortable taking their word on the condition of the outboard but knowing a general price range will help me negotiate the price.
  #7
Old January 29th, 2009, 09:36 AM
Chris1956 Chris1956 is offline
Deputy, You can just bore the scored cylinder, and save a few $.
Whatever route you take, you need to fix the problem that caused the scoring. It is usually caused by overheating or lean fuel mix. A new impeller( I would install new thermostats as well, for good measure) will fix the overheat problem, and cleaning the carbs should fix the lean condition. Check the condition of the oil pump drive gear, while the motor is apart, to make sure it is within tolerance.
  #8
Old January 29th, 2009, 11:18 AM
If I would just bore the one cylinder would this cause the engine to run rough? Or would there be a possibility of sleeving the scored cylinder?
I am still waiting on the service manager from the dealer to contact me with more details of what is wrong with this.
I am definately interested in the cause of the scored cylinder.
  #9
Old January 29th, 2009, 11:38 AM
Faztbullet's Avatar
If it has overheated the other cylinders are going to be scuffed or out of round. It is a 20 year old engine that has likely pulled skiers and it is due for the other cylinders to be serviced. That engine can be bored up to .030 on the 2.4 and .060 on the 2.0.A oversized pistion weighs the same as a stock piston so you can run std and oversize together with no problem.
__________________
  #10
Old January 29th, 2009, 05:35 PM
QSS QSS is offline
Hey faztbullet i was just reading this thread and didn,t no you could do that. run different size pistons together.. thanks for the info.. will help us with our problem...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 Johnson 150 V6 Low Compression bartowair Johnson & Evinrude Outboards 5 October 3rd, 2008 07:55 PM
Help Low Compression 95 Evinrude Ocean Pro 150 barry123 Johnson & Evinrude Outboards 10 June 15th, 2008 05:19 PM
150 gt low compression nogo Johnson & Evinrude Outboards 3 August 23rd, 2006 07:43 PM
87 johnson 150 compression low rickdog67emtp Johnson & Evinrude Outboards 14 May 7th, 2005 01:41 PM
low compression on 1989 Johnson 150. homey Johnson & Evinrude Outboards 11 January 19th, 2003 08:38 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
