bullets_full
- Nov 8, 2008
- 6
Hi all,
I have been painstakingly been trying to get my 115083d motor running. I just bought the motor off a guy on craig's list with boat and trailor. He told me that he had it running last month which after hours of troubleshooting found that that was a bunch of B.S. being that I already found the starter motor solenoid and ignition switch to be bad.
Sorry for the rambling but here's my question. Where is the safety switch circuit? My guess is somewhere under the flywheel which I have yet to remove because the bolt is rusted. I found the purple/black wire coming off the power pack going to the terminal block but the purple/black wire that should also be there going to the safety switch circuit is missing. So basically, all the testing I followed from the service manual for hours on end was all for not. I found this replacement part which I think may be it if the one there once I find it is bad but I'm not quite sure:
http://www.ebasicpower.com/pc/CDI133-5008/OB-OMCTRIGGERS/Sensor,+Johnson,+Evinrude
Can someone please verify this for me? Also, any suggestions for any experienced old salty dogs regarding this motor would be greatly appreciated.
Thank you!
Thank you!
