mercury black max 150/200 shift interrupt switch?
I have a 1990 (I believe) serial number 6305277 (motor cover is 150, but seller told me it is a 200??) It is a black max and here is what happened. Warmed-up engine and backed off trailer. I put the engine in neutral and the hot-foot was sticking so as to keep the rpms from over-revving I shut the engine off with the key. When I pulled the hand throttle back into neutral and went to turn the key, nothing. Seems just like when you try to start your car and it is in gear. Opened the engine hood and verified it is in neutral. Only fuse I could see was the breaker style which should pop out under the master power toggle switch in front of the hand throttle, it was pressed in. Boat is a 1990 18ft basstracker. Oil injector removed and mix own gas and oil. When I say nothing, it is as if I am not turning the key at all.
