  #1
Old January 24th, 2009, 10:17 PM
strokeoluck strokeoluck is offline
Default new boat owner prop questions
We just purchased a 2005 Bayliner 185 runabout. We are first-time boat owners and plan on using it for general inland lake fun w/our two young kids. While at the MN boat show today I talked with some "prop folks" and have a couple questions for the forum:
1) A lady from pirahana.com was telling me about the benefits of this "plastic" (?; composite?) prop that has pieces that just "pop out". I guess the idea is that if your prop gets dinged up, you just smack the broken/chipped plastic "fin" (?) out, and pop a new one in; for a $20 instant repair instead of a $100 prop repair. What are your thoughts on such props? Are they durable/reliable? Are they easy to repair on your own?
2) If we just plan on gently cruising around some inland lakes, pulling the kids on a tube or maybe skis, and just a tad bit of fishing now and then - do I need to worry about the "pitch" of the prop? Or should I just stick w/the standard pitch recommended by the boat manufacturer? There is a brand new prop on the boat (4.3L Merc by the way) - I have no clue what the pitch is. And the seller gave me the original prop as well - that's a little dinged up.
Thanks guys!
__________________
2005 Bayliner 185 4.3L I/O Mercruiser. New boaters as of 12/08.
"Make hay while the sun shines."
  #2
Old January 24th, 2009, 10:24 PM
bhile's Avatar
bhile bhile is offline
Default Re: new boat owner prop questions
IMO those composite props are good for emergency use only. I would never consider running one all the time. As far as the other prop(s) we neen to know your RPMs at WOT.
__________________
Fair Winds and Following Seas
Bill
PTC USN ret
  #3
Old January 24th, 2009, 10:28 PM
Silvertip Silvertip is offline
Go to the top of the forum and read the sticky titled "READ THIS FIRST". And just so you know, there is no such thing as a "standard prop". What comes on the boat when you buy it new may not be the correct prop for the intended use of the boat. And yes, the proper prop is important no matter how the boat is used.
  #4
Old January 24th, 2009, 10:48 PM
Rocky_Road's Avatar
Rocky_Road Rocky_Road is offline
Thanks guys!
You probably have everything that you need already...a good main prop, and a useable 'spare' to carry onboard. Just get yourself a floating prop nut wrench, a spare prop nut (along with tab washer, etc.)...just in case you need to use the spare.
You can drive yourself crazy...once you get yourself into the nether world of 'what prop is best for me?' If your current prop allows you to reach your printed max RPM...you are there.
If it ain't broke...don't fix it!
P.S. Do stay away from the composite props...you can hit something with an aluminum, or stainless steel, prop...and usually drive away. Ain't going to happen with a plastic prop!
  #5
Old January 24th, 2009, 10:54 PM
Cool, thanks Rocky.
__________________
  #6
Old January 25th, 2009, 12:00 AM
And a prop follow-up question for the group. Let's say I want to buy a replacement prop or two - as spares. Where do I go to find the cheapest aluminum prop that matches the two current props I have? Is this something I can do online? Is there some sort of model # or other unique info on the prop that would help me in ordering another one?
By the way, I did read the "read this first" post at the start of the thread. But I'm afraid I don't know the answer to a few of those questions - such as rpm at WOT. Heck, I don't even have the owner's manual. I did print one off the Bayliner website, but I'm not sure it's the right one yet.
Thanks.
__________________
  #7
Old January 25th, 2009, 02:23 AM
DJ DJ is offline
Have you looked at the prop selection here on iboats?
http://boatpropellers.iboats.com/
  #8
Old January 25th, 2009, 07:11 AM
mthieme's Avatar
mthieme mthieme is offline
For a 'spare' prop, new wouldn't be my first choice.
You might try any marinas or boat repair shops that might be in the area for a less expensive used prop. There's always a famous auction site too.
__________________
Nothing is so broken that Government can't make it worse.
  #9
Old January 25th, 2009, 09:23 AM
steelespike steelespike is offline
If you look on the barrel of the prop or under the prop nut there should be a number _ _ X _ _ Diameter X pitch.May only be a part number.There may be
a label on the motor indicating the max rpm. The best way to evaluate your setup is to give us the prop numbers,the max rpm and test it and give us the
present max rpm and speed.(gps speed is best)You allready have a spare prop your dinged up prop can be repaired as a spare.If it isn't dinged up too badly you could use as is just use it as little as possible.More than likely your new prop will serve well for the casual type use you describe. Get us the prop numbers and if it is aluminum or stainless(aluminum will be painted) we can give you an idea what
its performance will be like.But we'll still need the test numbers to be sure it allows the motor to operate within its rpm range.
  #10
Old January 25th, 2009, 11:31 AM
Rocky_Road's Avatar
If you have the Mercruiser 3.0L (in line 4 cylinders)...your max RPM's will be 4800.
'Dinged' props can be fine, as spares. Next time you are at the launch ramp, take a look at what other boaters are running, as their main prop. You will be surprised how much damage a prop can have...and still be a good, functioning, prop! Post a picture...and we can give you our opinion!
One spare prop is all that 99% of boaters will ever need to carry (use that extra prop money, to buy something really cool...like a depth finder). Where they usually fall 'short', is forgetting to have a short piece of a 2x4...to make the prop change even possible. My piece of wood has a bungee cord, that holds it in place...freeing up both hands, to make the change.
  #11
Old January 25th, 2009, 05:55 PM
I have the 4.3L Merc.
We have a Lowrance depth/fish finder and GPS unit - although of course I don't know how to use it yet. I printed out the manual. It's huge, and I have yet to start reading it. I'm not incredibly mechanically-inclined, so where would I go to learn how to change a prop? I tried looking on YouTube but couldn't find anything. We're taking a power squadron course in mid-March, perhaps they'll cover it there?
__________________
  #12
Old January 25th, 2009, 07:33 PM
Rocky_Road's Avatar
Your 4.3L is 4800 max RPM...here's a link:
http://www.perfprotech.com/store/art...fications.aspx
As for the prop change...it is pretty straight forward. Look at your prop, and you will see a locknut, with a tab washer (with bendable tabs) underneath. You bend the (usually 3) tabs away from the spline washer...and unscrew the nut. This is where you need to do this at home...BEFORE you head for the deep blue sea. Because the nut may be overtightened (and you will not get it loose, on the water)...and the prop shaft may need some grease (once again...you don't want to learn this floating behind your boat). Grease the shaft, and reinstall the nut to around 55 ft lb. Don't forget to bend 3 of the tabs back down. The block of wood keeps the prop from spinning, during all of this.
A floating prop wrench (usually yellow colored reinforced plastic) can be found at any marine store.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
A new boat owner has stupid questions snmpgh Wellcraft Boats 3 May 26th, 2009 03:39 PM
New Boat Owner, couple of questions walk1355 Johnson & Evinrude Outboards 1 May 18th, 2008 08:30 PM
New boat owner...few questions Termite Johnson & Evinrude Outboards 4 August 23rd, 2007 05:46 AM
New boat owner with questions hydro556 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 23 June 21st, 2007 08:12 AM
New boat owner, have many questions. Cruzomatic Boat Topics and Questions (not engine topics) 7 September 12th, 2005 05:08 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
