Quote:
Originally Posted by bhile
Yes you have a thermostat and no you shouldn't run without it. Its needed for your motor to tun efficiently. Also when is the last time you replaced your impeller?
Quote:
Originally Posted by Laddies
All of bhiles post and the reason you have a pulse in the telltale is the thermostat opening and closing. Most stats have a notch in them so they don't stop the flow completely
Thanks for the replies.
The motor is actually a friends. I have a couple of earlier model motors and he ask me if I could change the impeller on this one. He bought it used and wanted to put in a impeller before he began using it. Which I did with no problems. When I saw the intermittent stream and followed the line to the head port, I figured there must be a thermostat. Just wanted some verification.
Yes a manual would be a good investment and I am going suggest that he purchase one.
