Re: Sea Rayder F16 Mercury Sport Jet 120xr - jet pump oil
I don't know who you've been talking to. Slide under the boat and look toward the front of the ride plate and you will see two screws. One is labeled drain, the other fill. Pull both and let it drain out. Once empty, pump oil into the fill hole until it comes out, then reinstall the screws.
