I have a l983 Johnson 140hp V-4. It is fairly fresh with 128 in one cyl and 130 to 135 in other three. It runs out of gal on top in. I run a 19 pitch OMC stainless prop. Reaches 5000 rpm for about 4-5 seconds then falls on it's face. Frankly, I think it hit that rpm with a 21 pitch. It also will sneeze and surge(about 2-300 rpm idling in gear) then sometimes die. I have Boyson reeds and read in a forum that you should rework the idle jets with them. What does that mean? Enrichen or lean them? Also, what kind of timing can I put in it? The cover says 28 Deg. My engine rebuilder said he retarded that about 4-5 Deg for the break-in. I now have about 25 or 30 hours on it and have long ago gone to 50 to 1 oil. The boat (1983 17ft Glastron-Carlson) has tons of low end but not top. Can trim the 19 prop out and get 5400-5600 rpms but only 41 mph (GPS). I guess because of the small prop. The motor is on a 8inch mechanical set back all the way down. I also put a new fuel pump on it, the box said it was for a 20-30hp outboard. The mechanic said they are all the same. That doesn't sound right to me but, as I said I'm new at outboards. Any suggestions?
