which epoxy resin??
1beanie
which eposy resin do u guys recommend for sealing marine plywood for flooring? thanks
oops!
Re: which epoxy resin??
the cheapest you can get ! :)
i dont think it matters what name is on the can
i386
I use the 635 thin epoxy resin from US Composites with slow hardener. Every kit I've ordered has been of consistent quality and they ship fast. With the temps dropping, you might want to give them a call. They may recommend a faster hardener. The stuff I use takes too long to cure below 70 degrees, but they carry medium and slow hardeners.
