  #1
Old January 22nd, 2009, 10:09 PM
quikstang347 quikstang347 is offline
Unhappy 97 Mariner 125 Compression issues
Hello to everyone on this site i am newly registered here but have been reading the forums for years.
I have a question to pick your brains,
i just recently purchased a 19' trophy center console with a rebuilt 125 mariner on it. Yes i have the paperwork and talked to the marina that did the rebuild to support this. my question is that i took the boat in for a basic check up and a new impeller to be installed. once i got the boat there i wa stold i had the following compression readings
#1 130
#2 20
#3 130
#4 130
the only issue i have with this is that i took the boat out and it ran fine. ran 5500 rpm no problem no noise no issues ran at 40 mph. all of a sudden i throttled down due to an on coming wake and the boat died and would not restart. got it towed in and the next morning still the same . pulled al of the plugs and changed them (carbon fouled) thought it would start and no go. next i pulle dthe carbs and cleaned the jets reinstalled and walla it fired and ran fine. that is when i took it to the marine mechanic, this is a reputable shop but a small one. i am just wondering with a boat engine that has sat up for a while is there a special way to reintroduce it to being used. the motor was rebuilt with all new pistons new everything. #1 and #2 were sleeved and bored .030. the mechanics say i most likely have a broken piston. but with no damage on the plugs this si hard for me to believe. i am no boat mechanic at all. the motor is a 97 125 the case has to be split for the rods and pistons to come out. this is a lot of work for a diag that may just be stuck rings. is there any way i can tell before i authorize a large repair bill. i am an ase master tech for automobiles but know nothing about outboards. thanks for all the help in advance it is greatly appreciated.
p.s.
the impeller was wiped out no peeing from outboard at idle only while moving. would #2 overheat before the rest of the cylinders. thanks again
  #2
Old February 7th, 2009, 06:06 PM
Default Re: 97 Mariner 125 Compression issues
stuck ring on #2 needs a new piston it was from overheating .
  #3
Old February 7th, 2009, 06:45 PM
Faztbullet's Avatar
Faztbullet Faztbullet is offline
I would like to know why if #1 & #2 were resleeved, that they were bored.030 over? Resleeving them would have brought the back to standad size. One cylinder cannot overheat from a weak impeller, ALL will overheat and in a Inline engine #1 & #2 go first. I would check other pistons for scuffing and replace ring on the also.
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
97 150 faststrike fuel pump issues Nitro Rick Johnson & Evinrude Outboards 4 August 3rd, 2008 11:06 PM
97 200 EFI Merc starting issues xcspxlt Mercury & Mariner Outboards 0 May 23rd, 2008 02:13 PM
97 Evinrude 150 Starting Issues clc13e Johnson & Evinrude Outboards 2 March 26th, 2007 03:18 PM
1987 force 125 compression issues Headhunter7 Force & Chrysler Outboards 4 July 2nd, 2006 02:40 PM
impeller change on '97 Mariner 125 quantumleap Mercury & Mariner Outboards 5 March 12th, 2004 06:02 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
