  #1
Old January 22nd, 2009, 07:10 PM
john0974 john0974 is offline
Default 70hp evinrude misfires only when idling
hi guys i have a 78mdl 70hp evinrude it only misfires when idling but when running doesn`t miss at all i have replaced plugs,coils,had all wiring replaced,i am running rite fuel to oil mix,had timing checked,carbies have been serviced,compression is 121 on all cylinders please help i have had it with boat mechanics and there ridiculous prices
  #2
Old January 22nd, 2009, 07:52 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: 70hp evinrude misfires only when idling
Does it just seem to drop a cylinder and just fade away & quit?
  #3
Old January 22nd, 2009, 08:05 PM
CharlieB CharlieB is offline
You still need to follow the basic troubleshooting to determine the problem.
Using and inductive timing light, verify that you have spark on all cul's at an idle to rule out an ignition problem such as a broken wire at the pivot point at the timer base.
Once spark is verified then it is safe to assume that the problem is in the carbs, either not synch'd together well enough or a slight fuel or air restriction in the idle circuit, just enough to NOT fire at an idle only, yet run perfectly well from just off an idle and all the way to WOT.
Trim the motor enough to level the carb float bowls, with the air box cover off, and the motor OFF, open the throttle WOT, look down the carb throats while squeezing the primer bulb. You are looking for ANY fuel leaking into the throat of any carb, indicating a faulty needle/seat or incorrect float setting allowing that cyl to flood at an idle.
If all carbs look good, then close the throttle, add water and stir, warm up the motor and proceed.
With the air box cover off and running at an idle, stick a finger into the throat of one carb, top, then center, then bottom. Notice any difference? Try again with two fingers. If the offending cyl is too lean then the finger trick/test will act llike a choke, fattening the mixture.
One of these three test should show your problem.
This is assuming the the linkage on the carbs are sync'd.
Depending on yr, make, model, the linkage between the carbs should NOT be touching the throttle cam at an idle. If it is a model that sets idle speed by throttle position then carefully pull a pin, or bolt, such to disconnect or turn the throttle cam away from the carb linkage while you are synching the carbs. Remember how to put it back to the same position once finished. There should be a screw on two or all three carbs pivot or on the linkage at the connection to the pivot. Carefully loosen all these screws, ensure that each carb pivots freely and is allow to close completely, carefully re-tighten each screw such that once the linkage is tight then all carbs are closed AND that all carbs open in sych. Done.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
70HP Johnson Idling problems ACAMACIAN Johnson & Evinrude Outboards 7 August 3rd, 2009 12:49 AM
Problems idling - 1999 70hp outboard jmossqs Johnson Boats 1 June 13th, 2008 12:31 PM
68 evinrude starts but idle's bad and misfires buckeye700179 Johnson & Evinrude Outboards 15 May 17th, 2004 11:26 AM
95 Johnson 70HP quits while idling. Wetbuck1 Johnson & Evinrude Outboards 7 June 17th, 2002 09:04 AM
1991 Evinrude 70hp Problems (idling) jguy Johnson & Evinrude Outboards 3 May 8th, 2002 09:49 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
