  #1
Old January 22nd, 2009, 12:36 PM
chasntail chasntail is offline
Default Aluminum floor in jon boat
I have decided to raise the floor in my jon boat. I am going to use aluminum sheet for the flooring. I want to put hatches in the floor but I dont want the plastic hatches sold at bass pro or one of those places. what I am looking to do is cut out holes in the floor and use a piece of aluminum for the cover. my question is how do i go about making this waterproof?I thought about putting a channel around the cut out acting as a water trough from there connecting hose to it and running it over board. does anyone have any other ideas on how to go about keeping water out of the storage area?
  #2
Old January 22nd, 2009, 12:47 PM
cbavier's Avatar
cbavier cbavier is offline
Send a message via AIM to cbavier
Default Re: Aluminum floor in jon boat
Quote:
You won't be able to keep water out completely. No matter how good of a job you do it or try. You absolutly will need a bilge pump if you put a floor in your boat. Also remember putting a floor in the boat will raise the center of gravity thus making it more prone to captsize so be very careful. I think you would be better off to make side compartments. You could configure the length and size to fit your needs. You could even line them with carpet for noise reduction and protection of your gear.
__________________
Chuck
"OWN-IT"
1986 Four Winns, Horizon 190
4.3, 185 HP, Alpha One
Calkins Roller Trailer
  #3
Old January 22nd, 2009, 12:56 PM
Thanks for the reply. Im not to concerned with stability its a jon boat and its 24ft long 6'0 beam at the bottom of the boat it is very stable. I am putting two bilge pumps under the floor just case but my main concern is keeping everything under the floor dry. I have a large family 5 kids myself and my wife and even with the biggest jon boat they sell its still not enough room. I am just looking to keep everything out of the way.
  #4
Old January 22nd, 2009, 01:43 PM
marquette marquette is offline
i think cabela's sells (and maybe iboats) aluminum hatches that are designed to be covered with carpet so you can add a hatch and only have the outline of the hatch. they might be worth looking at to see if they would work.
how do you plan to attach the floor to the side of the hull to keep water from running down the side and underneath. most aluminum boats with floors allow the water to follow the hull till it goes under the deck and in to the bildge. inthe boats i have had with hatches most of the storage is damp storage at best, wet storage at worst. the only dry storage i have had is when you put the plastic box in that seals between the floor and the hatch and the hatch is a waterproof hatch. i think most manufactures use the plastic hatches with the o-ring if they want true dry storage. i found it has been a lot simpler to match the hatch to the floor and then use waterproof boxes and bags rather than try to seal all the water out.
  #5
Old January 22nd, 2009, 01:52 PM
My plan is to run aluminum sheeting down the sides of the boat im thinking 1/16th of an inch for that. I am using deck bars from a tractor trailer to support the floor some 18 inches off the original floor. now where the floor and sides meet I am using aluminum channel to catch the water and drain it out the thru hull fittings. when complete the floor and the side of the boat will be almost seamless. this is still in the thought process everyday i think i change something about it. my intention is once the floor is laid to my standards I am going to have it rhino lined mainly because of slipping when wet. I would carpet but with all the kids carpet wont last long. I have a carpeted floor now and it already has holes in it.But i will look into those aluminum ones you are talking about. thanks for the reply
  #6
Old January 22nd, 2009, 06:41 PM
sschefer sschefer is offline
Sealing up hatches is pretty simple. I take a piece of 1/2" "z" bar and make a lipped frame then rivit it to the bottom side of the opening. I glue a piece of automotive weather stripping to the lip all he way around.
When closed and latched, the cover contacts the seal and you are waterproof. Mine don't leak even when I wash the boat down.
If you wanted to get really trick, you could add a knife edge to the cover and make it a submersable seal.
  #7
Old January 23rd, 2009, 12:06 AM
sschefer thanks for the reply I was having the same idea and was wondering if anyone else every tried it before I go and spend the 1500+ on the aluminum needed. I am glad to hear that it works doing it this way. thanks for the reply
  #8
Old January 23rd, 2009, 06:22 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
look at this one. http://forums.iboats.com/showthread.php?t=286547
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #9
Old January 23rd, 2009, 07:16 AM
coolguy147's Avatar
coolguy147 coolguy147 is offline
lol 24ft long thats longer then my pontoon and my neigherbors pontoon. thats one big john boat
__________________
http://photobucket.com/sgdteam
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
What is something like rhino lining i can do the floor of my jon boat with? Dank Xploidz Boat Topics and Questions (not engine topics) 5 December 2nd, 2008 11:09 PM
Re-Painting Aluminum Jon Boat BoatsRCool Boat Restoration and Building 2 December 7th, 2007 12:06 AM
painting an aluminum jon boat. mschex05 Boat Restoration and Building 2 June 9th, 2007 09:44 PM
Painting aluminum jon boat booboo7353 Boat Restoration and Building 7 February 14th, 2007 09:06 AM
Jon Boat Floor Repair ChrisVZ Boat Restoration and Building 5 September 3rd, 2005 08:24 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
