Re: how to remove flywheel hub on 1983 mercury 150
First you should never disassemble a flywheel sxcept to change the flex plate, never put a puller on the outside flange as it can warp and cause the flex plate to crack. Get the Mercury type puller so you don't damage the hub and it should come off.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
