  #1
Old January 21st, 2009, 11:53 PM
sampler sampler is offline
Default 1973 Evinrude 65hp bad piston
just got my first boat and motor. well to come to find out that the 65hp motor has a bad piston. did compeson test on all 3cyl on had 0 on #1 and 135 on #2 and 135 on #3. so pulled head and found #1 cyl had gone bad. so is there any one that may have pistons for 1973 evinrude motor65hp??? or know where i can find new ones or used?
  #2
Old January 22nd, 2009, 04:48 AM
james williams's Avatar
james williams james williams is offline
Default Re: 1973 Evinrude 65hp bad piston
Try `maxrules.com`
  #3
Old January 22nd, 2009, 05:18 AM
jay_merrill's Avatar
jay_merrill jay_merrill is online now
Try sea-way.com. The shop.evinrude.com site says that the part is "dealer direct now," which means that Sea-Way may not have it (they are a BRP NOS warehouse), but its worth a try. If you can't find a new one, you may have to go with a used piston and a set of new rings.
Another possibility is to pick up a parts motor with a good powerhead. That route may be easier from a parts standpoint, and is a lot less work.
Sorry to hear of your bad luck, but at least you have learned one thing - bring the compression tester before you buy! I also hope that you have had a word or two with the seller. While he/she may not have known exactly what was wrong with it, even someone with minimal mechanical aptitude should have known that something was wrong.
  #4
Old January 22nd, 2009, 08:14 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
new one are a dealer direct purchase. http://shop2.evinrude.com/ext/index....cfd8a6471c0f7f
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #5
Old January 22nd, 2009, 11:15 AM
Might need more than a piston. Need to check cylinder.
  #6
Old January 22nd, 2009, 11:24 AM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Wiseco has them in std, .020, .030 and .040 over. You have to use the B1029 wrist pin bearing so they'll work on the old rods.
  #7
Old January 22nd, 2009, 09:08 PM
James R James R is offline
Master Chief Petty Officer
Cool Re: 1973 Evinrude 65hp bad piston
Pistons should be available through you OMC dealer. You will need to take the motor apart, have the cylinder bored and replace seals etc. With a cylinder in real bad condition there may be a con rod problem or a crankshaft and bearings problem. If you are not familiar with rebuilding it can be a painfull learning experience. The big question is do you think it is worth the cost of rebuilding. To find this out you need to know all the parts needed and what you will need to do.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1973 Evinrude Triumph 65hp Luger Johnson & Evinrude Outboards 3 July 5th, 2008 12:37 AM
1973 65hp johnson piston to bore clearance lark2004 Johnson & Evinrude Outboards 1 July 27th, 2006 08:03 AM
1973 65hp evinrude grayman Johnson & Evinrude Outboards 2 July 19th, 2003 11:15 AM
1973 65hp evinrude likearock Johnson & Evinrude Outboards 2 November 10th, 2001 01:33 AM
Piston Assembly for 1973 65hp Evinrude Ramo Johnson & Evinrude Outboards 1 March 26th, 2001 01:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
