cobra outdrive
rojoc
Is there any way, from a cobra outdrive model number, to decipher what year or size the drive is off of? thanks in advance.
rojoc
Re: cobra outdrive
good suggestion. so here they are: 986037 985271 983844, any takers?
a70eliminator
Re: cobra outdrive
The model and serial numbers of the vertical drive are stamped on the plate located on the vertical drive, this number is used to identify the vertical drive and to match it with the engine, so your answer is yes.
rojoc
Re: cobra outdrive
Thank you for the reply. I assumed there would be a correlation between outdrive model numbers and engine sizes but wanted to know if any of our learned friends on this site knew what the model numbers actually designated.
Boatin Bob
Re: cobra outdrive
983844 1986 5.7 gear ratio 1.41:1
985271 1988 5.0 gear ratio 1.50:1
986037 1990 5.7 gear ratio 1.41:1
rojoc
Re: cobra outdrive
thank you for the info. How was the years and sizes determined? Thanks again.
Boatin Bob
Re: cobra outdrive
Each model # represents a specific size and year, you just have to have the model # info to cross reference them in the documentation.
