ALANJOHNDAVIS
- Oct 29, 2008
- 2
I Work And Live In Papua New Guniea, I Have A 2004 F200 O/b On A 22 Ft Centre Console The Motor Has Done 1500 Hrs And Has A Problem Bogging Down When You Start To Go, Engine Starts, Idles, And Trolls Well, But When You Try To Give It Full Throttle Straight Away It Boggs Down And Can Stop Some Times, When This Happens If You Hand Prime The Fuel Pump The Engine Will Pick Up. I Have Tried Fitting The 25 Litre Fuel Plastic Tank Direct To The Engine Bypassing The Racor Fuel Filter, And Makes No Diffrence, I Have Replaced The Spark Plugs, Had The Injectors Removed And Cleaned By Yamaha And Fitted A New Low Pressure Pump And High Pressure Pump This Also Has Made No Diffrence, Any Ideas?
