  #1
Old January 18th, 2009, 02:09 AM
reelfishin reelfishin is offline
Default Freeze damage to aluminum hull
I went today to look at an open 16' aluminum boat, something I've been looking for for a while, the price was right and when I got there the boat was sitting turned upside down on some logs but not covered.
It looked decent but when I grabbed the rail to flip it over to inspect the inside, noticed that the gunwale rails were all split open, some splits still had ice pushing out of them.
Being that it was left to sit upside down, a good idea to preserve the inside, the open seam of the only riveted gunwale rail let water fill up that tube area, when it froze, the rail split open like a frozen water pipe. The boat had several huge cracks along the gunwales, some nearly full length of the boat.
Needless to say I walked away but I think it's worth making note of when storing a boat upside down outside in freezing weather. I think that boat would have been better off if left upright and covered, or even uncovered and just stored bow upwards. It was an open hull with no wood, so there's nothing that would have rotted other than maybe the transom wood which was surface mounted anyhow.
I wonder how many other boats have this same issue if stored belly up?
  #2
Old January 18th, 2009, 09:10 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Freeze damage to aluminum hull
ice can be very destructive..
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old January 18th, 2009, 11:31 AM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Common freeze damage. No big thing to fiz just get it welded of you thinks it interferes with support or you could hammer it down (the splits) and jb Weld it.
Be sure to drill a few drain holes for the future and make sure they are clear when it is stored.
The splits and the ice are good for you if you are going to buy the boat.... they become bargaining points on how much money it will cost to replace it
I have a double atv trailer that has built in aluminum ramps and they have split from water/ice too. Just like a pipe split in copper in the winter..... no panic..... just repair and move on!
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
  #4
Old January 18th, 2009, 02:48 PM
Tim Frank Tim Frank is offline
Quote:
Always nice to hear the inside scoop on ice-damage from our friends in Florida....especially after we have just had a week of 20 below....
  #5
Old January 18th, 2009, 06:09 PM
Mark_VTfisherman's Avatar
Mark_VTfisherman Mark_VTfisherman is offline
Quote:
So you guys are the ones that sent that 29-below-zero night...
__________________
Clean feet are happy feet; same for boats.
1964 MFG Niagara Deluxe
  #6
Old January 18th, 2009, 06:36 PM
Hanr3 Hanr3 is offline
I have a 1957 Alumacraft 14' boat that I bought last January from an inlaw. The boat was half full of water, er ice. Literally half full of ice. I put it in my gargae to thaw and it took two weeks.
I took the boat out this past summer a few times and it doesn't leak at all. As pointed out in the original post, yes it is better to store it right side up. When water freezes it expands, that can be veryt destructive, and the reason we have pot holes in hte street.
PS
the heat wave started ysterday, we are up to 9 above 0. Last week it got to 50 degrees below freezing plus the wind chill. That's cold.
  #7
Old January 18th, 2009, 07:15 PM
Bob_VT's Avatar
Quote:
So where do the pot holes come from in hot climates??? I have been to the Florida Keys and I never suspected that the pot holes were from freezing!!
I have seen 4' deep pools freeze solid which is common.... as long at there is room to expand. I always stored my boats bow high and plug removed to drain if any water got past the cover.
My 14' Starcraft is stored upside down on the trailer....... between the snow, ice and leaves it stays cleaner. If the rub rail ever spilts ....... I will fix it.
  #8
Old January 27th, 2009, 10:21 PM
The one I looked at was pretty badly split, you'd have to spend all day hammering cracks closed and welding. They would also always show since most were right on top.
I have two that no matter what, won't drain all their water out, even if put several feet higher in the bow, the drain plug hole is about 2" above the bottom due to a rear rib that crosses right at the bottom of the transom. Super strong but not the greatest for draining. The drain tube extends into the boat 3", or just past that last rib. (Standing it up vertical would allow water to accumulate up to that tube. just wrap it up and keep the bow high, all should be fine. Just so no water is trapped or inside any structure all should be fine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum boat with possible minor hull damage TN-25 Boat Restoration and Building 6 October 10th, 2008 02:18 PM
Possible freeze damage Tail_Gunner Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 11 February 16th, 2007 12:12 PM
freeze damage....update bauerterry Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 10 May 19th, 2005 08:50 AM
I/O freeze damage temp?? dermon Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 7 April 2nd, 2003 08:15 PM
Freeze Damage rickyp52 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 26 March 30th, 2003 08:33 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
