  #1
Old January 17th, 2009, 05:38 PM
halh68 halh68 is offline
Unhappy Mercury 650 cooling problems.
I have a 1970's 650. I had only a drip from the pee-hole. I replaced the impeller and still the same. the hose to the lower unit is clear and pumps plenty of water if removed on the block end. the pee hole had some trash. It was cleaned out and still the same. Any help on where to go from here would be appreciated
Thanks.
Hal
  #2
Old January 17th, 2009, 09:00 PM
Default Re: Mercury 650 cooling problems.
does this engine have a thermostat and where is it if so?
  #3
Old January 17th, 2009, 09:35 PM
Laddies Laddies is offline
No your engine does not have a thermostat. The early engines like yours pick up the water for the telltale at the bottom of the exhaust cover and will not clean out properly the best solution it to move the pickup point most of those block are taped on the top for a water pressure gauge move the telltale pickup to that plug and cut the old hose as short as possible and plug it.
__________________
PLEASE, no service questions in PMs thats what the forums are for.
  #4
Old January 17th, 2009, 10:55 PM
would there be a pipe plug or something in the top of the block if this is the case?
thanks again
  #5
Old January 17th, 2009, 11:10 PM
Yes it should be 1/8 pipe, some did not have one in the top but on the water jacket cover betwen the plugs. The top is the best place as it purges the air out of the block.
__________________
  #6
Old January 17th, 2009, 11:46 PM
thanks, i'll check it tomorrow and see.
  #7
Old January 18th, 2009, 12:09 AM
the hose to the tell-tale comes out of what the back of what i think is the fuel pump 2 fuel lines connect toward the front and the water hose from the lower unit and the tell-tale hose hooks toward the back
  #8
Old January 18th, 2009, 12:11 AM
did you mean hook the hose from the lower unit to the top of the block or the hose to the tell-tale?
thanks again
  #9
Old January 18th, 2009, 11:05 AM
I was giving advice for a 4 cyl 650 it sounds now like you have a 3 cyl am I right?
__________________
  #10
Old January 18th, 2009, 12:42 PM
yes its a 3 cyl 1976 im pretty sure. there was a plug in the head between the top 2 cyls
  #11
Old January 18th, 2009, 01:09 PM
Ok, on that engine there is a thermostat and popit valve, they control engine tempiture but have nothing to do with the telltale flow. On that engine the water is pumped up the tube to a chamber that supplies the engine with cooling water through the thermostat and popit bypass and has a hose that come out of the spacer plate that supplies water to the water cooled fuel pump which dumps it over board through the tell tall. Start by pulling the hose off the spacer elbow and start to check flow, there will probably not be any because the plastic elbow that the hose came off of is usually plugged or melted inside remove it and restart if there is water the elbow was the problem if no water take a piece of hard wire and put it in the hole and try to rod it out with the engine at high idle, if that don't work the power head will need to be removed as the adapter plate is plugged or there is a blown gasket. If there is water at the elbow with the hose removed then either the fuel pump is plugged or the 2 hoses. All of this of course is counting on a good pump from the w/pump and remember just blowing air through it proves nothing, it takes water to flush it.
__________________
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
cooling question mercury 650 dungbeetle46 Mercury & Mariner Outboards 3 October 20th, 2008 10:15 AM
650 cooling problems pod184 Mercury & Mariner Outboards 3 July 26th, 2005 01:14 PM
'69 Mercury 650 cooling problem PuckHog Mercury & Mariner Outboards 4 July 5th, 2005 09:31 AM
1974 mercury 650 cooling problem? albert71 Mercury & Mariner Outboards 2 July 17th, 2002 03:08 AM
older mercruiser 650 outboard having cooling problems... monguse Mercury & Mariner Outboards 1 May 24th, 2001 08:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
