  #1
Old January 17th, 2009, 12:18 PM
nuw2boating nuw2boating is offline
Default Bought used boat, need information
I just bought a 2000 aquasport 215 osprey, 21' dual console, with a 2000 evinrude 200 hp outboard. I have 3 questions, all of which I'm embarrassed to say I don't know the answer to!
1) Is this a good boat? or a bad buy?
2) Can anyone tell by the ser. number on the motor what type it is? (2 stroke? 4 stroke?) ser.g04793661
3) what type of trailer should this boat be on? I think it should be a dual axle.
The dry weight of the boat is 3215 lbs.
  #2
Old January 17th, 2009, 08:59 PM
QC's Avatar
QC QC is offline
Default Re: Bought used boat, need information
1) Almost any boat can be a good boat, and all most any boat can be a pile. Generally speaking I believe that is a sound hull. That's the most important piece, as all of the other stuff can be replaced and is generally the same from boat to boat. We'll help you keep her a good one. Just needs TLC her whole life. Not sometimes, all the time.
2) Repost that question in the JohnnyRude forum below vvvv dive captain, dive . . . oooooh gaaaaaah. Hopefully a 2 stroke Ocean Runner? Maybe a FICHT?
3) Tandem axle with brakes. Period. You are probably over 5K lbs all up with that combo.
Have fun, be careful and welcome aboard.
__________________
Havasu Falls, Grand Canyon
  #3
Old January 18th, 2009, 12:54 AM
Soundbounder's Avatar
Soundbounder Soundbounder is offline
I don't know the condition of it, but Aquasport always made a good boat.
They have had a very good reputation.
  #4
Old January 18th, 2009, 01:36 AM
TheRealSangster TheRealSangster is offline
congrats on the new to you boat. Hope you have lots of fun with it!
on a more serious note, did you really buy a boat without finding out if the motor is 2 or 4 stroke?
  #5
Old June 6th, 2009, 11:00 AM
aclmvh's Avatar
aclmvh aclmvh is offline
Aquasport is a great boat. I've had an 18' CC for a number of years with a Johnson 115, and its a solid rig. For the most part, construction is all fiberglas including the stringers and the transom. Hope you enjoy yours as I have mine.
  #6
Old June 7th, 2009, 12:58 PM
Home Cookin' Home Cookin' is offline
Master Chief Petty Officer
don't run the engine until you know what it is, and learn about mixing fuel and oil. And as you learn about boats, keep this in mind: A boat is like and unlike a car, just as a horse is like and unlike a motorcycle. You are in a whole new world, I started to say after the steering wheel but even steering is different! be safe, be cautious. But you will be OK b/c you started off asking questions; it's the ones who don't care about what they don't know that end up broken down or as casualties.
  #7
Old June 7th, 2009, 01:44 PM
Silvertip Silvertip is offline
If you don't know the difference between a two stroke and a four stroke engine I suggest you not even look at the key until you understand what it is you bought. Failure to understand this can result in a very expensive learning experience. Just a hunch here but I think you have an Evinrude, it is a two stroke engine, and it is a much hated FICHT (that's techno speak for an early direct fuel injection system). Here is the short version.
Two stroke engine: Requires a mix of fuel and oil (called OIL injection) or if that auto-mixing feature has been removed as it often is, you MUST mix two stroke outboard oil (branded TCW-3) on the container at a ratio of one pint per every six gallons of fuel. If your engine is a FICHT, it is also FUEL injected (direct fuel injection or DFI to be precise). You do not have to change oil on a two stroke. Run these engines without oil and I hope you have a lot of extra bucks in your piggy bank.
Four stroke engine: These engines are just like the engine in your car. It has an oil pan, a dip stick, valves, timing belt or chain, and you do NOT mix oil and fuel. It may be FUEL injected or carbureted. You DO check dip stick for oil level just like you do (or should do) on your car at each fuel fill up. These engines also require frequent oil and filter changes.
Sleep well!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Bought used boat, need information rndn Boat Topics and Questions (not engine topics) 8 January 16th, 2009 08:34 PM
Just bought 1982 RENKEN Need information.. anything helpful Wingeier Renken Boats 1 July 6th, 2007 05:21 PM
Bought a used boat/motor and need to know the year 2fast2live Non-Repair Outboard Discussions 1 January 30th, 2007 08:02 PM
Need information on a used boat LuckyPenny Boat Topics and Questions (not engine topics) 1 July 24th, 2004 12:05 PM
Used Boat need any Information smyrnaman Force & Chrysler Outboards 4 April 28th, 2002 05:25 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
