  #1
Old January 17th, 2009, 03:05 AM
grrr_evans grrr_evans is offline
Default Painting Aluminum!
Hey everyone out there, this site is AWSOME!
I am going to paint my aluminum boat and I have Tremclad aluminum primer and then a Tremclad paint and I was wondering if that would work? also I had to take quite a bit of out paint off and there is still some spots that I couldn't get all the paint off, I don't know what paint was on there and I was wondering if the Aluminum primer would stick to that paint too?
Thanks everyone!
ooo ya and is there anyway to keep aluminum from oxidizing? like a clear coat or anything?
  #2
Old January 17th, 2009, 08:36 AM
5150abf's Avatar
5150abf 5150abf is offline
Default Re: Painting Aluminum!
Never heard of that brand but it sounds like you have it.
Aluminum primer has an acid base that actualy eats into the metal and makes it stick, so if you are using aluminum primer and the paint that is suppose to go with the primer not much can go wrong.
I would check to see if you will get a reaction in an out of the way place and preferably on a paint edge, where bare metal meets old paint.
If it doesn't react nothing willhappen, if it does the old paint will shrivel up and look kinda like a raisin.
Etching primer will stick very well to the old paint and you only need to remove the old finish if the paint is bad and not sticking to the hull anymore, otherwise just a good scuff is fine.
Just painted mine a couple weeks ago with a base/clear coat.
Remember the finished product will be as good as your prep, 95% of paint is in the prep,I spent @ 35 hours sanding ect and 2-3 hours actually painting
As far as oxidizing you woul dhave to use a shark hide type product for that as it is made to stick to aluminum, clear coat would eventually flake off I think.
This a project that is worth every second, its almost like getting a new boat with out the payments.
Here is how mine turned out, get up some pics if you can
__________________
GO IRISH!!!!
  #3
Old January 17th, 2009, 06:59 PM
kandil's Avatar
kandil kandil is offline
If you want to go all out you should try an electric sander and go at the old paint other Wise you should sand the old paint so the new paint well adhere to the hull good luck and post a photo or 2.
  #4
Old January 17th, 2009, 09:11 PM
DJ DJ is offline
If the old paint is stuck on there-leave it. Just fair out the edges.
Any bare spots should be washed with a 50/50 solution of White Vinegar and water. That will "etch" the bare aluminum.
The bare aluminum spots should be painted with Zinc Chromate primer. That will also etch the aluminum.
Your primer should go on everything-after that.
Top coat final.
  #5
Old January 17th, 2009, 09:34 PM
rtpassini's Avatar
rtpassini rtpassini is offline
Send a message via MSN to rtpassini
i thought tremclad was a branch of rustoleum....
  #6
Old January 17th, 2009, 10:22 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Do a google search on tremclad..... look it up and see if it is used for marine use. Rustoleum has a marine paint made for the job.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
painting aluminum izzybird Boat Topics and Questions (not engine topics) 8 October 12th, 2008 11:19 AM
painting a aluminum boat RUSTY.B Boat Topics and Questions (not engine topics) 1 April 28th, 2005 08:35 PM
Aluminum Painting newf1 Boat Restoration and Building 3 March 30th, 2005 05:13 AM
Painting aluminum rick3b Boat Restoration and Building 3 February 7th, 2005 03:52 PM
Painting aluminum shipoffools Boat Topics and Questions (not engine topics) 1 February 27th, 2004 09:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
