  #1
Old January 16th, 2009, 06:45 PM
davidf5252 davidf5252 is offline
Default Mariner 115 solenoid or starter problem.
I have an inline 6 cylinder Mariner 115.
I used the boat over 30 times last year without issue. The boat has been in the garage for about 4 months with no use.
I decided to charge the battery and fire her up as i was thinking about going fishing.
So with a fully charged battery (actually tried 2 different batteries just to make sure it wasnt a bad battery.), brand new terminal connectors to ensure a good connection i turn the key and all i hear is "CLICK". Not multiple clicks like a car with a dead battery just one click and nothing happened...
I got a volt meter and checked the solenoid and it is getting power.
I called a few places and they said it was probably the solenoid...so i went and picked one up... heck for 23 bucks it was worth a shot.
I just installed the new solenoid and nothing changes....
I am at a loss and cant afford to pay someone $75 per hour to track down the issue plus cost of repair.... so i turn to you guys here at iboats for some advice and wisdom.
Please help!! if you need more info i will be checking this every few minutes...
Thanks to all that can help!!
  #2
Old January 16th, 2009, 08:36 PM
Laddies Laddies is offline
Default Re: Mariner 115 solenoid or starter problem.
If you have a voltmeter hook it on the input post on the starter and see that you have voltage then the starters engaged if you do the starter is bad.
  #3
Old January 16th, 2009, 08:39 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
The below guide is for a Merc 150, but the troubleshooting steps would still pretty much apply to your motor too. Systematic troubleshooting is often much quicker and cheaper than replacing parts on a hunch. A voltmeter/ohmmeter (and perhaps also a jumper cable) is pretty much all you need.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
  #4
Old January 16th, 2009, 08:46 PM
Quote:
im a newb with outboards... where is the input post located?
  #5
Old January 16th, 2009, 08:50 PM
Where the wire from the solonoid attaches. If you are going to try to do service work you will save yourself alot of grief with a OEM service manual,
  #6
Old January 17th, 2009, 06:05 AM
Maine Ducker Maine Ducker is offline
I just purchased a boat with a 70hp Merc and had the same problem. Just a click from the solenoid and everything tested fine. After much aggravation I finally figured out what was going on. Moisture inside the starter. I figured this out after pulling the starter out and bringing it inside for a day to warm up. After replacing it she spun freely and fired up no problem. Next day same problem again. Even though the boat is in the garage it still gets cold and even though you could turn the starter by hand it was still frozen inside. I ended up replacing the starter and now it's fine. Check Ebay for starters.
  #7
Old January 17th, 2009, 10:40 AM
Chris1956 Chris1956 is offline
My neighbor was an electric motor rebuilder. After my boat sunk, he washed up my starter and it tested shorted. He then put in a warm (200*) oven for 1.5 hours to dry up the interior of the coils. The starter was fine after that.
  #8
Old January 19th, 2009, 11:39 AM
great advice... i will try this over the next couple of days...
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1984 Merc 115 starter solenoid repairable? MortenH Mercury & Mariner Outboards 4 October 24th, 2006 12:29 PM
1992 Evinrude 115 starter solenoid check michaeljcarr Johnson & Evinrude Outboards 1 July 12th, 2005 08:02 PM
Slave Solenoid/Solenoid/Starter Problem? rocklydockly Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 6 June 25th, 2005 10:02 AM
Starter Solenoid Problem jjhpmag Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 September 30th, 2004 07:46 PM
Starter solenoid problem SS MAYFLOAT Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 June 27th, 2004 07:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
