My old Merc went broken last week after a few distinct bangbangbang.
Took the motor and powerhead apart and found that one piston was broken above the upper piston ring on approx one third of the perifiri of the piston top. Loose parts from piston blocked the engine from rotate. No marks on cylinder walls but...
...it looks like the cylinder lining has moved somewhat. Specifically on the cylinder with the broken piston but also, but less, on the other cylinders.
(Could this be the root cause for the piston to break)
If, but only if, the cylinder lining is expected to be positioned tight to the cylindertop, the worst cylinder lining is off some 3mm .
Is this a known issue with these Mercs ?
Can the cylinder lining be pressed back and expected to stay there for "another 20 years" or is it destroyed because it ones have moved out of position ( if it has)?
If possible how to do it? Just press or use some cold / heat treatment. Was thinking of heating the powerhead in th owen to 100 deg C and then insert a deep froozen piston into the cylinder and hope for the lining to be colder and crimp before pressing it back.
