I have been fixing up a 1960 40hp Johnson that had sat around at the previous owner's house for 7-8 years. I put in a new carb kit, fuel pump kit and done general cleaning of the exhaust manifold and other things that I thought would help it run. The problem I am having now is running the motor because when I start it, all I see is smoke out of the exhaust and no water. This I take it means the water pump isn't getting water to cool the engine off. (I'm running it in a 55 gallon drum) I took the pump apart and the impeller looks worn but not terrible. The seals and grommets and stuff could need replaced but my question is, is a water pump supposed to be completely sealed to create a vacuum for the water to flow? I guess I'm just confused on what I should do to fix it besides put a new impeller in it and hope. When I took the pump off, it didn't have any gaskets or sealer to keep it sealed so I didn't know what to do and/or where to put gaskets, sealants or seals, etc. Any info would be wonderful. Thanks!
