power trim prob?
Benny1963
1983 evirude 175 older three wire trim .
trim has new relay and wires and trim control switch on steering
motor is suspect , when i use my transom saver it seems to stick after i remove it and go to trim down . my down trim is faster than my up
but it should be the other way around up uses selinoid
fluid is full motor seems to sinn beeter going down than up
just dont want to replace motor then have to but trim
and possiblty have to covert to two wire .
any info will help thanks bennyb
