Re: Resealing A 800 stringer Uppere and lower
No problem for you beef.
Of course gonna need the kits.
The upper cause of the water pump in some units will always have water cause of the design.
And the stikin clutch housing you already must know always has water.
Couple tools you will need, real long truarc pliers, all they are are long needle nose, snap ring pliers.
I made my own with i think a 12' measured to the cross needle nose ground down the tips.
You already got pullers, i had to make a connecting bar.
And i made another puller.
Look if you run into a problem pm me ill send you my phone number.
