Green Celta
- Oct 23, 2008
- 2
I have recently purchased a 2005 Johnson which has seen very little use and is in excellent condition.
When I fitted the motor to the boat and place the tilt/run lever in the run position and in forward gear, the motor still appears to be in a locked position and does not lift up with reasonable pressure applied.
I also use a 7.5 Mercury which is an older motor without a tilt/run lever, when in forward gear it lifts up easily to avoid damage when hitting submerged logs etc.
Is this normal for the Johnson or do I have a problem.
Thanks for your help.
Kev.
Kev.
