Where can I find a diagram of the fuel bleeder lines
4Bassin
on a XR6 carbureted outboard? I need to replace all of them and some were broken behind the ignition assy. I'm not sure where all of them go now since they were so rotted they fell apart.
Also, all I could find was a 3/16" vacuum line. I am not convinced that it is gasoline or oil resistant. I have a piece soaking in gasoline right now to see if it turns to mush. How long do you think I should let it set and where else can I get the proper hoses? I don't want to risk a blown power head over a $2 rubber line.
**Never mind, search is my friend, sorry for the post....
Chris1956
Re: Where can I find a diagram of the fuel bleeder lines
My Clymer Service Manual has pictures. A Merc Service Manual will have them also.
Try to get 3/16 neopreme lines, if you cannot get fuel line.
4Bassin
I found the information below. I have a Seloc manual and after I was done I accidently stumbled upon the diagrams in it. I looked in the fuel section and it wasn't there. It was however in the powerhead assembly section. Again, thanks all...
