  #1
Old January 11th, 2009, 07:04 PM
tkess987 tkess987 is offline
Default 03 4stroke 115 yamaha - cuts out occasionaly
Short and sweet. Occasionaly if I am cruising slowly at 2,000 or so rpms and quickly put throttle in neutral. Engine will cut out? Happens more when backing off trailer and putting back into neutral. If I do it smoothly - does not seem to happen..( which I do try to be smooth with the throttle) I haven't changed spark plugs in a while. Could that be the problem.. Not a real big problem now, but I would like to head off any future real problems..
Thanks
  #2
Old January 11th, 2009, 09:59 PM
gcboat gcboat is offline
Default Re: 03 4stroke 115 yamaha - cuts out occasionaly
Why don't you just go ahead and do a tune up on the motor, at least get that out of the way. Also check you RPM's at idle - might be low ( in gear ).
There could be a lot of reasons for this to happen but start with getting the motor fresh. Never know.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
  #3
Old January 16th, 2009, 05:54 PM
bossee bossee is offline
Hi,
I have a Yamaha F115 also, 2003.
Only time my F115 has stopped was after a service Yamaha dealer made and they did not screw on the built in fuel filter correctly on the threads so it did not seal properly. I found out by taking the cowl off and then I could see some gas dripping at the fuel filter. I unscrewed and and screwed it on properly on the threads so the rubber seal could seal as it was intended.
Other that that my F115 had never stopped and I have used it since I bought it new 2003. Great outboard by the way. Here is a picture of my F115 where I'm cruising in about 30 knots a hot summer day:
/Bo
  #4
Old January 16th, 2009, 06:53 PM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
great shot bossee, i agree with previous advise, get the tuneup done.
  #5
Old January 17th, 2009, 03:27 AM
sdsaw sdsaw is offline
Does your motor struggle to idle smoothly when you drop down to idle speed but eventually smooths out?
First, do as the others have already said; Get a tune up; Change spark plugs.
If the symptom still persists, try cleaning your IAC (idle air control valve) with some carb. cleaner, toothbrush and compressed air.
I have the 2001 Mercury version (Yamaha powerhead) and over seven years of ownership, have cleaned it 3 times which cures the idle issue.
I have always had trouble backing off the trailer and not stalling the motor... I'm thinking it's because it isn't warmed up enough.
Just an idea.
Hope it might help you.
Scott
__________________
"Somebody put salt in the ocean to punish us boaters"
1989 22' Bayrunner Cuddy (Aluminum)
2001 Merc. 115 Saltwater Series Fourstroke
1988 Yam. 9.9 High Thrust Fourstroke
1998 Dodge 2500/ 24V. Cummins diesel
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury outboard 40hp 4stroke/cuts out outboardgal Mercury & Mariner Outboards 0 June 29th, 2008 07:59 PM
Yamaha 115 cuts out @ 1/2 to 3/4 throttle Skeeter180 Yamaha & Suzuki Outboards 0 August 23rd, 2007 12:00 PM
' 02 Yamaha 115 4stroke EFI problems acm022 Yamaha & Suzuki Outboards 5 July 13th, 2006 02:53 PM
impeller replacement on 03 merc 115hp 4stroke enoch310 Mercury & Mariner Outboards 0 April 23rd, 2006 01:08 PM
Yamaha 25hp (2stroke)? Nissan 18hp(4stroke)? Honda 15hp(4stroke)? Spidybot Non-Repair Outboard Discussions 4 October 26th, 2003 06:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
