Re: 02 yamaha 150 buzzer/wont start
Couple things. When you swapped the motors, did you have to re-rig it with the same control cables and such or did the Angler have the rigging for a yamaha motor? May sound dumb, but did you make sure the lanyard is connected? I have a 115 txra and from my limited knowledge, there is only a couple things that cause the buzzer to go off, two major ones being overheating and the oil level floats.
I had an issue where one of the oil injection system indicator wires got loose and was was grounding out against the engine. Check all of your connections to make sure they are connected.
