Dshow
- Jan 1, 2007
- 313
I have a 2001 Merc with an Alpha 1 Gen 2 outdrive that has ~130 hrs on it. (I've had it for 2 seasons) I pulled the outdrive for the first time as I was winterizing and had a few questions:
1) From reading the forum, it sound like it is common to pull your outdrive. Is it necessary to replace all gaskets/o-rings every time you pull it (every season)?
2) When you pull the drive, how do you grease the u-joints? I didn't see any grease fittings on the u-joints?
Thanks!
Thanks!
