Cut the outdrive gear oil hose
Status
Not open for further replies.
krisnowicki
Since my cracked gimbal ring I have take off the bellhousing redid all my bellows and what not. also changed my gimbal bearing. When I was cutting the bellows so i could get the off easier I cut right through the hose that goes from the bell housing to the transom. The hose that sends gear oil to the oil monitor bowl in the boat. So obviuosly I have to replace it now. what kind of hose is this I have the size but will fuel line or fuel injector hose work?
45Auto
Re: Cut the outdrive gear oil hose
1/4" marine fuel line will work fine.
Don S
Why don't you get the right stuff from your local Merc dealer?
krisnowicki
I was at marine maxx (my local mercruiser part dealer) to get some paint for the od and I asked the counter guy about it he said to just go buy a hose from pep boys because he didnt have it in stock.... wtf. Thats when I came home and got on here to see what kind
achris
More fish than mountain goat
Get it form one of the on-line shops...
krisnowicki
I bought a marine fuel line hose... it was eaten through by the syn oil. So i got the merc hose today. It took 3 days to get shipped by whatever,
but all day while I am working on this thing i was thinking of don s's sig line.
I just wanted to let every one know that marine fuel lines wouldnt work if you were in the same jam is the reason for my post.
Thanks
Speakrdude
Ensign
So what steps did you have to take to replace the hose? Did you have to remove everything?
dubs283
the odds of this person waiting for someone to ask them a question about their more than two year old problem are pretty slim
re activating an old thread usually dosen't get you very far here
i have read the thread you started about you gear lube line issue but i am having a hard time making sense of it
try re-wording it very plainly, describing what you noticed, where exactly you noticed it, and what you have done thus far
Status
