  #1
Old January 7th, 2009, 11:43 PM
wanttofly's Avatar
wanttofly wanttofly is offline
Default prop
Bought my first boat last year. I was a little disapointed with the pulling power of the boat. I have a 5.7 with a 19 three bladed prop. I do live 5500 feet up so I know that reduces the power of the boat, but I am going to switch to a four bladed prop. Wondering what pitch to go with? I am willing to give up top end speed. Am I expecting to much of a 1990 21ft boat fully loaded to be able to pull a big man out of water at 5500 feet up?
  #2
Old January 8th, 2009, 08:59 AM
gcboat gcboat is offline
Default Re: prop
Couple of questions first. What is your WOT with the existing prop?
How long have you owned the boat and has this always been the case?
Reasons for the questions: You should be able to turn between 4800 to 5200 with that motor. Anything less and you're straining it, anything more and you might see parts fly off. Critical to keep those paramaters as close as possible.
If this is a new boat to you and the symptoms have always been this way then there just might be other areas that need attention.
How do you regain this lost power? For most boat owners, you don’t. The most effective way to regain the lost power is to install a supercharger or turbocharger. While possible, this isn’t practical for most boat owners. (Note: As horsepower goes down, rpm goes down, too and changing to a lower pitch prop to get the engine speed back into its recommended range will help.
As we go up in elevation, air density becomes less and those engines fitted with carburetors will begin to run rich. For prolonged operation at higher elevations (generally for two or more weeks at an elevation of 4000 feet or more) carbureted engines can be improved by installing smaller main jets to get the fuel/air ratio back to where it belongs.
__________________
Life may not be the party we hoped for, but while we are here we might as well dance
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1996 Force 120 Bent Prop+New Prop=Grinding/Vibration @ Low-Mid RPM justinbentley Force & Chrysler Outboards 3 July 20th, 2006 06:10 PM
Converting Alpha I, Gen II single prop to dual prop? Road Head Prop Questions and Topics 1 July 11th, 2006 12:34 PM
prop keeps wearing on housing, looking for diagram of prop shaft setup micktater Mercury & Mariner Outboards 4 July 6th, 2004 03:12 PM
Prop / prop shaft wrong on '67 V4 60HP Evinrude? Tinkerer2 Johnson & Evinrude Outboards 9 February 4th, 2004 05:06 AM
Volvo Duo-Prop vs. Single Prop...Please Help Tearlach Non-Repair Outboard Discussions 1 April 4th, 2002 11:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
