Re: Help 35 Horse Chrysler Outboard Problem
Even given the angle of the photo, the engine still looks like it is sitting too deep in the water---The long shaft insert is 5 inches and it appears that the anti-ventilation plate is sitting about 2-3 inches below the hull bottom. Therefore the transom is a long shaft transom but a bit short--like maybe 18 inches deep instead of the usual 20. That happened a lot on older boats. but that's not your problem
Check the prop hub for a spun hub. If it is spun, the rubber donut inside is deteriorating and it will happen at progressivly slower speeds.
Your local marina or boat dealer can send it out to a prop shop for re-hubbing. When I had my first Chrysler, re-hubbing cost 5 bucks. Now it's probably about 35. Back then, a Michigan bronze two blade racing prop for that engine cost 25 bucks.
At any rate, You may be able to pick up a used prop on the auctions for that price. Your prop is a stock prop made by Columbian props. Usually the size was stamped into one blade at the root. It will be something like 10 3/8 X 12 1/2. There will also be a number under the tailcone like A 293265. This is a 10 3/8 diameter by 12 1/2 pitch aluminum prop. Even if you do get your prop re-hubbed, it is still good insurance to have a spare on board.
Once you get the engine and prop running correctly, then try raising it on the transom until the anti-ventilation plate--also known as the cavitation plate-- is even with the bottom of the hull when the plate is parallel to the bottom. A straight piece of wood held against the plate helps to measure.
Raising the engine is free and can result in gains from 2-5 MPH.
