Rebuilding MFG 1958 Cambridge
Status
Not open for further replies.
beezer3
I need some help with a way to connect the wood deck to the fiberglass hull.
all the rubrails i see don't fit, plus it should be red. not black or white.
Hope someone can help
thanks, R
Mark42
Re: Rebuilding MFG 1958 Cambridge
There is a company that makes the red rub rail you need. I don't remember right now who it is, but when I check the favorites on the different PC's I have I might come across them again. Meanwhile, you should search the MFG forum to see if you can find a post where a member found the red rub rail. If I remember right, it is only available on custom order.
Tjriley
Beezer I am also restoring a cambridge that I just purchased. Did you ever find the rub rail?
GA_Boater
Old, old, old topic. Beezer Made one post 6 years ago. This is dead!
pckeen
Hi TJ, It's not proper to begin posting on a thread more than 90 days old unless you are the original poster. It confuses people, and can cause a member who left this thread years ago, to start getting messages about it again. Don't reply to this or post questions on this thread. Start a new thread in this section with the questions you have and I expect you'll get lots of help.
Status
