  #1
Old January 7th, 2009, 09:13 PM
cfaulkner cfaulkner is offline
Default 9.8 hp Mercury 110,loss of power
my 1978 9.8hp has no top end power,it used to push my boat up on plane,now it gets only about half speed.It starts fine and idles well(no stalling)I changed the gas and checked the plugs.Does anyone have any ideas where I might check next? Thanks
  #2
Old January 7th, 2009, 09:25 PM
DJ DJ is offline
Default Re: 9.8 hp Mercury 110,loss of power
Wrong area, moving to Merc. Outboards.
  #3
Old June 14th, 2009, 12:38 AM
bigdrip bigdrip is offline
May have to clean bowl and jet intake. Had similar problem and found alot of soft material clogging intake and bowl. Engine would start and run just no power.
  #4
Old June 30th, 2009, 04:41 PM
dajohnson53 dajohnson53 is offline
Quote:
Is it getting good, consistent spark at both plugs? Could be that one cylinder is not firing or only firing intermittently. A quick and dirty way to check this is to remove one spark plug wire while it's running. If the engine quits, that means the other cylinder is not firing. If the engine cuts down in power that means both cylinders are probably firing equally (but not necessarily at full potential). If the engine does not change, it means the cylinder you disconnected is probably not firing properly.
If your findings indicate one or the other cylinder is not firing properly, then you go through the process to figure out what's causing that single-cylinder problem. Spark plug, plug wire, coil, switch box are the normal culprits and there's simple trouble shooting steps to check those in an organized way. Carb feeds both cylinders equally so that's usually not the case.
If your test doesn't show a single cylinder being the problem, to me it would indicate that for some reason both cylinders have a problem - that could be fuel or spark, but the spark part would be something that affects both equally as opposed to something that affects one or the other.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1985 Mercury 115 hp power loss 85Lund Mercury & Mariner Outboards 27 May 10th, 2009 12:28 AM
2001 4 stroke 50 hp mercury power loss!! swantek1 Mercury & Mariner Outboards 4 March 19th, 2009 09:11 PM
Johnson 110 power loss teflonharry Johnson & Evinrude Outboards 7 August 5th, 2004 03:29 PM
Mercury 65 hp has power loss yorel Mercury & Mariner Outboards 4 June 5th, 2003 08:02 PM
loss of power 1981 75 hp mercury ob mercrude Mercury & Mariner Outboards 3 December 28th, 2002 03:34 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
