  #1
Old January 4th, 2009, 11:32 PM
two2imes two2imes is offline
Default 89 MERCURY 115hp Starting/Choke issue
All was working fine then wouldnt start as normal. Got stuck on water and had to be towed
Manually opened choke and she fired right up revving quite high, then blew a fuel line and fuel started pouring out but relieved as it did start and shouldnt be too major. any ideas on what to try ? Does this mean my choke is broken or maybe fuel pump ? (obviously need to replace busted fuel line)
Thanks in advance from first time poster . . .
  #2
Old January 5th, 2009, 07:08 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 89 MERCURY 115hp Starting/Choke issue
fix fuel line, then try it. could be just that simple.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old January 5th, 2009, 12:06 PM
Chris1956 Chris1956 is offline
Does that motor have choke plates? Normally the later models have a enrichener system that pumps raw fuel into the carb throats.
I had thought choke plates went away by the mid eighties.
  #4
Old January 5th, 2009, 03:40 PM
hey - def not cause of the fuel line - tht burst today and boat wouldnt start for a week/out on the water. Not sure what choke plates are but has silver disc thingys that cover the 4 carbs or intake thingys.
  #5
Old January 5th, 2009, 04:16 PM
I looked up a '89 115 Merc. It is a four cylinder inline motor, four carbs and no choke plates. It has a motor mounted enrichener solenoid, which is connected to the fuel pump and dumps fuel into the carbs to richen them up for cold start. Is that what you have? If you are opening the throttle plates, the motor will naturally speed up.
  #6
Old January 5th, 2009, 09:09 PM
Hey- yes thts my engine . . . . so if the choke isnt working, what should i try ?
  #7
Old January 5th, 2009, 09:14 PM
ok sorry i may be getting confused - i keep calling it a "choke" but i guess its not from reading this - its the pre starting mechanism. Sorry
  #8
Old January 6th, 2009, 11:49 AM
OK - Remove the airbox so you can see the carb throats. Now push the button on the top of the enrichener solenoid and pump the primer bulb. You should see fuel run into the carb throat. Now have someone push the choke button and the solenoid should activate and again you should see fuel in the carb throats. if you do not see fuel, troubleshoot the system and see if the power is not getting to the solenoid, or the solenoid or fuel lines are bad or clogged.
  #9
Old January 6th, 2009, 07:52 PM
hkeiner's Avatar
hkeiner hkeiner is offline
Ensign
To add to Chris's good advice, follow the below guide to further troubleshoot the enrichener system.
__________________
1996 Mercury 150HP V6 carbed outboard motor and Maxum 1900XR bowrider boat
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Choke problem 89 Mercury 20 HP ali*cats Mercury & Mariner Outboards 2 June 27th, 2008 10:55 PM
'89 60hp Mercury fuel issue? Jgreen Mercury & Mariner Outboards 2 June 9th, 2008 05:00 PM
1983 115hp Mercury bogging down or choke problem? TimDollar Mercury & Mariner Outboards 20 January 30th, 2007 04:06 PM
1979 Evinrude 55hp choke/ starting issue trackerdave Johnson & Evinrude Outboards 29 June 20th, 2006 09:57 AM
choke issue (starting procedure?)(solenoid?) 90 hp 6 cyl merc stratodoc Mercury & Mariner Outboards 9 August 7th, 2003 07:33 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
