  #1
Old January 3rd, 2009, 07:56 PM
cprince's Avatar
cprince cprince is offline
Default What is the difference; Tin & Aluminum? (And other Questions!)
I am not a metallurgist. That is likely painfully obvious by my thread title. I have a removable bow and aft casting deck project that I will get going in the spring. I am a cheap bugger and I am looking for cheap to free sources for my building material.
The decks will be aluminum as I want it to be super light weight and strong and I want it to last.
My bright ideas are as follows;
Aluminum framing/skeleton -
Will be made out of a couple of crushed/damaged aluminum ladders; Is this a good idea? Are these generally safe to use and strong enough (of course NOT using the damaged parts!).
Decking - Here is where it gets REAL muddy for me... I was thinking about using old aluminum siding... if I can find some. What I can easily get is corrugated tin roofing from the farm. This old roofing has never rusted and it has been outside for years. Could this mean that it is actually aluminum and NOT tin? I don't know the difference by looking at it. I think that tin visibly rusts and aluminum not as perceptible...
If the consensus is that this is not appropriate material to use, what would be suggested? (Think free scrap or REAL cheap!)
I will be fastening this all together with pop rivets and, perhaps self tapping screws. I will finish off the decks with exterior carpeting glued down with contact cement.
Thank you!!
__________________
Look out Pike, Here I come!
My Current Restore Thread; http://forums.iboats.com/showthread.php?p=1852224#post1852224
My Old Restore Thread; http://tinyurl.com/3sv6gt
My Old restore blog; http://princescraft.blogspot.com/
  #2
Old January 3rd, 2009, 08:29 PM
a70eliminator a70eliminator is offline
Default Re: What is the difference; Tin & Aluminum?
A magnet will not stick to aluminum.
  #3
Old January 3rd, 2009, 09:05 PM
jonesg jonesg is offline
Real tin is extremely expensive, its the golden colored lining inside of food cans , its a very thin coating, inert. Probably just a few atoms thick.
Corrugated non rusting roof sheeting is probably galvi.
  #4
Old January 3rd, 2009, 09:40 PM
Shizzy's Avatar
Shizzy Shizzy is offline
Ensign
Default Re: What is the difference; Tin & Aluminum? (And other Questions!)
keep in mind just because you are building it out of aluminum doesnt mean it will be lighter. something overbuilt in aluminum will weigh the same as if it was made of wood.
__________________
'68 Alumacraft FD, '65 Johnson 6HP "The Sea Monkey"
  #5
Old January 3rd, 2009, 09:45 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Road signs, stop signs and most highway signs are anodized aluminum. Go to a scrap yard and hunt around for old signs. The men working signs used to be 4 x 4 aluminum and have since been replaced by poly signs. Go to a highway maintenance garage and scrounge. Aluminum ladder sides will work great for structure.
If you mix aluminum with other metals (Tin, steel etc.) you will cause corrosion due to premature Galvanic corrosion.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum engine parts - good, bad, no difference? tmh Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 3 July 16th, 2008 07:00 PM
difference between aluminum and SS PowerAddict Prop Questions and Topics 8 June 15th, 2008 07:12 PM
Difference between Yamaha 401 & 403 control box (edit 701 & 703) Mike Robinson Yamaha & Suzuki Outboards 4 June 6th, 2006 02:09 AM
props....stainless vs. aluminum..... how big a difference? Sea Hawk Mercury & Mariner Outboards 7 September 2nd, 2002 10:00 PM
4 stroke tiller on 14ft tin. garycunn Boat Topics and Questions (not engine topics) 4 February 14th, 2002 02:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
