I just baught a 79 Bass Tracker. I put the rabbit ears on the motor and it fired up after a few cranks. It runs ok just no water coming out of the weep hole. Could it be because there isn't enough pressure from the rabbita ears? Is it better to submerge it and then test it out? Also, is the weep hole up by the motor case? Thanks!
