SkyKing917
- Oct 16, 2008
- 3
I have an 88 90hp Johnson. The tilt/trim was working slowly, barely able to tilt the motor. I tried filling the fluid and running up and down and few times and refilling, but no success. Removed unit from outboard and discovered tilt motor was full of hydraulic fluid. Do you think this is my problem? Is this normal? I suspect not, but wondered if it was a cooling feature or something. Assuming this is not normal, is there a seal on the tilt motor I could replace, or do I need to replace the whole motor? I am considering replacing the entire trim/tilt assembly because a used one may be cheaper than just a new tilt motor. Any thoughts on this? Thanks for your help.
