Hi there
I have a DT140 which is late 1980's I believe.
The motor pretty much runs sweet apart from one issue, if the water is quite choppy and I come down with a bit of a wack the motor seems to cut suddenly then will slowly power up again. I'm not touching the throttle at all, it just does it itself.
Looking at other posts I believe this could possibly be an issue with the "Cooling Water Sensor". Would others agree this is a good place to start? And what would be a good place to source the part from on the net? I could contact my local dealer however it may be cheaper online?
I took my one out and it looks a little dirty but nothing obvious sticks out to me like it being broken or anything (unless it has internal workings you can't see).
Would appreciate your help.
And hi from NZ! Cheers, Aaron
