Help. I have just bought a 6hp evinrude outboard through e.bay (advertised as hardly used and runs great). So far have replaced impeller, ignition coils and condensors and it is now running as expected. Checked the gearbox oil and it was white. Changed oil and again white. No sign of oil at prop, so suspect drive shaft seal. I am getting conflicting advice on which way the seal is pressed in. Should the seal "spring" face the power head or the gearbox. i.e. is it trying to hold the oil in or the water out?
Thanks in advance, I am a new user to this forum.
Les
Les
