  #1
Old December 31st, 2008, 02:41 PM
jerryyow jerryyow is offline
Unhappy Oil injector pump on 1998 150 mercury
I got a beeep beep ....warning on the alarme at over 4000rpm's and traced down the problem to the oil pump gear. My oil pump gear that drives the oil pump shaft appears to be made of plastic and has sheared off most of its threads inside the shaft housing. I vacumed all of the shavings, and the pump works at low engine RPM's.
How much of a job is it it to replace this gear in the engine block, and what is the downside of removong the pump shaft and just running motor on 50/1 premix??
Engine has about 300 hrs of runtime and warm compression is 115psi on 5 cylinders, and 85psi on the #6 bottom cylinder.
Any ideas as to why this gear failed??
Is this a common problem??
  #2
Old December 31st, 2008, 04:33 PM
gss036 gss036 is offline
Default Re: Oil injector pump on 1998 150 mercury
Lots of posts on the subject. Major engine tear down required to replace the gear. Mercury makes a kit/plug to replace the gear so you can run pre-mix. That by far is the cheapest fix. There is also a kit for an electric oil pump, but again cost big bucks.
Do a search and sit down w/a big cup of coffee and enjoy the reading.
  #3
Old January 1st, 2009, 12:51 PM
grootski grootski is offline
This is a common problem because the gears are plastic. Basically designed to fail. By the time you get the beep the engine is damaged. You now have low compression in one cylinder which would indicate scouring due to lack of oil. Pull the cylinder head and check it out. Do not run the engine with a damaged gear. Mixing is a little inconvenient but it is the only sure way to know an engine is getting oil. The cost of repair far exceeds the hassle of mixing. After the engine is repaired, remove the gear on the pump and reinstall it. Hope this helps.
  #4
Old January 1st, 2009, 05:20 PM
CharlieB CharlieB is offline
This is a very common problem on motors that are run at higher RPM.
Most ALL the hot rodded motors leave the gear out and strictly run pre-mix.
Replacing the crank gear requires splitting the cases, so you can understand this is not an easy fix.
That sixth cyl is hurt, enough so that you really are only running on 5, and should be repaired before Spring.
You have my vote for leaving out the crank gear, oil pump shaft, and oil warning module, get Religious about mixing your fuel.
  #5
Old January 28th, 2009, 01:13 AM
Smile Re: Oil injector pump on 1998 150 mercury
Thank you for the feedback, ran the boat again with 50/1 mix in tank, removed the pump shaft, and left the pump on the engine.to plug the hole.
Also dissconnected the switchbox to oil/temp module connection wire to stop the beep beep warning from the oil warning. Installed a waterpressure gage to monitor waterpump pressure to powerhead.
Operating RPM (5800rpm) and idel performance seemed normal and hopefully there was no major engine damage to the engine as compression came up on the weak #6 cylinder to 100#s after running the boat for a hour on the lake.
Thanks again
Jerry
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Two questions: bait well pump and oil injector trobinson017 Boat Topics and Questions (not engine topics) 9 September 21st, 2008 01:00 PM
1990 75hp Mariner w/oil injector; injector not working 93cobrastang Mercury & Mariner Outboards 2 July 24th, 2006 11:13 PM
Mercury 115 Oil injector broken. What ratio do I mix gas and oil in fuel tank? Kerry Elliott Mercury & Mariner Outboards 2 July 1st, 2005 08:18 AM
Enricher, Fuel Pump, or Oil Injector??? digitalt Mercury & Mariner Outboards 0 May 26th, 2005 06:22 PM
OIL INJECTOR PUMP smoker craft dave Mercury & Mariner Outboards 4 January 16th, 2004 10:58 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
