  #1
Old December 30th, 2008, 09:21 PM
mars bar mars bar is offline
Default Leaking rivets on small aluminum boats
Hey I found a way to fix those leaking rivets last summer. The boat in question was a springbok 14 ft. I was forever bailing and fixing till I got the idea.2 part epoxy, you know the small tubes. Sand and clean the area around the rivet(s) with alcohol, cut some circular pieces of shirt material ( the size of a loonie) Canadian hahaha, Half dollar piece. Cover the cloth as in doing fiberglass. Place it over the rivet and with a wet finger smooth out the bubbles. Let dry. Then require a spray can of asphalt undercoating and give it a shot to cover the patch. Extra coats may be added. This is the only thing that worked for me including JB weld.
  #2
Old December 30th, 2008, 09:23 PM
airframer's Avatar
airframer airframer is offline
Default Re: Leaking rivets on small aluminum boats
putting in a new rivet isn't that hard and its a permanent fix
__________________
jon boat with small merc
  #3
Old December 30th, 2008, 09:29 PM
kaferhaus kaferhaus is offline
I hear about these things leaking all the time, but I've never had one that leaked and I've had several riveted aluminum boats.
The current one I have is 18yrs old and it's the dryest boat I own! (Bass Tracker)
__________________
2002 26' Twin Vee (twin 150 Johnson's) FOR SALE!
2000 16' Dawson Flats boat (50HP Nissan)
2007 18' Caracal (140HP Suzuki)
2004 3070 Pursuit (twin 300HP Yamahas)
  #4
DJ DJ is offline
Even with a new rivet, I would use this.
See link.
http://www.iboats.com/Marine_Store/d...--submit%2Ey.2
  #5
Old December 30th, 2008, 11:11 PM
arks's Avatar
arks arks is offline
Quote:
Yeah, same here!
I think people must use them for ocean crossings or something that loosens 'em up...
__________________
"Winter Dream"
Silverton 34C
White/Green
Lowe 1446 BigJon
w/Johnson 25HP
  #6
Old December 30th, 2008, 11:49 PM
txmntman's Avatar
txmntman txmntman is offline
The link goes to a 2 part epoxy "Gluvit".....I have used it on a 1967 starcraft, and it is WONDERFUL! It will fix leaks, and is known as the aluminum boat's best friend....and I agree completely. It is a very good product, easy to use, and very, very effective....
  #7
Old December 31st, 2008, 12:44 AM
Shizzy's Avatar
Shizzy Shizzy is offline
Ensign
that does sound like a lot of work and ugly once you are done.
of course my 41 year old tinny doesnt leak a drop.
__________________
'68 Alumacraft FD, '65 Johnson 6HP "The Sea Monkey"
  #8
Old December 31st, 2008, 05:56 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Gluvit, is the aluminum boats best freind.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #9
Old December 31st, 2008, 11:09 AM
Mike2043's Avatar
Mike2043 Mike2043 is offline
I have 4 aluminum row boats that I use. All of them had small leaks when I got them.. I went to the local wallmart and picked up a can of spray on bed liner. The first time I used the spray cans. It worked. when I got my 3rd boat I picked up a 1 gallon can and brushed it on. That worked even better. You can make it as thick as you want and it stopped all leaks. Nice and easy.
  #10
Old December 31st, 2008, 11:18 AM
That Gluvit really holds to aluminium, never heard of it. Sure seems alot easier than the way I do things. Buy the way, were pretty rough with our boats here, jumping beaver dams and hitting deadheads.
  #11
Old January 5th, 2009, 11:33 AM
Floatsum Floatsum is offline
Interesting post.
I've been procrastinating on buying a used 19.5' Sea Nymph for ocean pounding.
Going to be fishing only. Guy just finished installing new decking with carpet.
Carpet is nice, but I hope to destroy it by next spring with Bluefish Juices and such.
If I can pull the deck without destroying, I'm thinking of Glovit on all rivets and seams followed by a roll-on bedliner material for quietness.
Would this be a good way to go or would I have problems?
I'd want to seal it once and forget it for many years.
Trying to locate some info on how I'd need to prep the aluminum (if any) to insure that the stuff sticks permenantly. No luck with it though.
Any advice to this method?
thanks
  #12
Old January 5th, 2009, 02:34 PM
DJ DJ is offline
Gluv It will adhere to aluminum if:
1. Grind/sand it, finishing with 220 grit paper.
2. Wipe with acetone.
3. APPLY WITH CONFIDENCE.
Gluv It is the aluminum boats best friend.
  #13
Old January 5th, 2009, 04:49 PM
txmntman's Avatar
What DJ said.....
Plus:
Gluvit does not have any UV protection (from what I understand). Therefore, you might do well to paint over it or protect it somehow. I have painted over mine on the aluminum boat, and have not yet had any problems with paint peeling. However, I only painted the boat about 9 months ago.
As I said earlier, Gluvit is great stuff! Use it with confidence!!!
  #14
Old January 5th, 2009, 05:32 PM
Bob_VT's Avatar
Bob_VT Bob_VT is offline
Well Gluvit creeps and flows when you apply it. It is best to tip the hull so it flows into the seams and it will stay there. I used it on the seams of my aluminum boats.
Takes some time to dry but actually remains flexible. JB weld tends to crack and re-leak.
You can apply 3m5200 but that does not flow like gluvit does.
__________________
"When you see yourself doing something badly and nobody’s bothering to tell you anymore, that’s a very bad place to be. Your critics are your ones telling you they still love you and care." Randy Pausch 1960-2008 The Last Lecture
SpinnerBait_Nut's Member Map Link Please add yourself http://www.frappr.com/iboats
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Aluminum Rivets rterrian Boat Topics and Questions (not engine topics) 7 April 24th, 2009 11:09 AM
Aluminum Rivets Leaking (again) alandchris Boat Restoration and Building 5 December 31st, 2007 09:08 PM
aluminum boat leaking from rivets slocke Boat Restoration and Building 5 August 3rd, 2006 08:43 AM
leaking rivets plewis Boat Restoration and Building 4 July 2nd, 2006 08:03 PM
Leaking Rivets! Howard Allen Boat Topics and Questions (not engine topics) 19 July 26th, 2001 05:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
