Re: Anchoring a boat off a beach
The water is deep where your going, you should hit bottom as long as you stay out of the coves, and away from the shore.
Also, some of the beaches out there will change water direction at night vs the day. So keep that in mind.
And dont tie too close to the beach thinking you will be up at 6 to get it into deeper water. tide will go down at 5am sometimes, and never go down on somedays.
Your going at an odd time of year. the water will be a little lower than usual.
but a STRONG word of advice. DO NOT. I repeat DO NOT try to drive from mojavi to Laughlin. The water is VERY shallow just between needles and laughlin. About 10 miles up from the bridge it gets dangerous. Trees an inch below water, rocks everywhere, random rocky sand bars. Gas lines. all hidden 1-6" below the water.
Dont even try it.
